Which Client to use
Which Client to use
On the wiki the screenshots of the cfclient shows setting on the main tab for the LED lights on the bottom left corner. Which build or branch is this from? I cannot seem to get that to show up.
Re: Which Client to use
You can find it on the develop branch:
-> https://github.com/bitcraze/crazyflie-c ... ee/develop
Unfortunately there has not been an official release for quite some time (hint hint
I'm guessing I don't remember eclipse as well as I thought. I updated my files with the current on the repository. I checked out a new branch. Still no go. Dug through history to where it was added. Tried checking that out. No matter what I try I never get any change to reflect in the client when I launch it. What could I be missing?
Just use the link to GitHub and click on the "Download Zip" button on the right side.
That version works. I just tested it.
Should also work when checking out with Eclipse. Are you sure you are looking at the right directory when you start the client?
If I read that right, I should be able to delete everything. Download zip and unpack it. Launch the client and be good to go?
I am new to Linux. Turns out there was a copy still in /usr/local. I was able to delete it. However if I type cfclient it would still try and start it. I downloaded the zip and if I run it with command python cfclient it works. If I dont put python first it tries to launch somewhere else. Is there an easy way to clean this up?
Maybe you installed the client with pip if it is in /usr/local
You can try:
You can try:
sudo pip uninstall cfclient
