				M2 Led fully lit... Seems not working
				Posted: Wed Jul 01, 2015 5:24 pm
				by Charliemr99
				I just bought the crazyflie 2.0, I did the assembling perfectly, but when I connected my iPhone to the CF, after 3 min, it turned off. After charging the CF, when I turn it on, only the M2 led is fully lit and the rest are off. What can I do? How can I reset the CF?
With battery and without it, is the same. Only M2 LED is on
				Re: M2 Led fully lit... Seems not working
				Posted: Tue Jul 14, 2015 12:10 pm
				by marcus
This could be caused by software. Could you try the following and see if it helps?
-  Make sure the Crazyflie is fully charged
-  Remove the battery and plug it in again
-  Try to turn the power on/off using the button a couple of times (if it doesn't start up correctly)
				Posted: Sun Jul 26, 2015 9:23 am
				by ericson
Same issue for me.
I upgraded the firmware, following the procedures (
https://bitbucket.org/bitcraze/crazyfli ... 4.01.0.bin)
Since then, M2 Led fully lit when CF turned on, nothing else.
I tried with other batteries, unplugging / plugging it, trying multiple times.
Any idea please?
				Posted: Mon Jul 27, 2015 6:58 pm
				by ericson
				as far as I'm concerned, problem solved: I downgraded my CF...
