I just assembled the craziflie, and I downloaded the iOS app. I tried to control the flie from my iPhone 5s. Bluetooth was turned on and the flie was connected. However, when I tapped my two fingers on the screen and moved around, nothing happened to my drone. Anyone know why is that?
I can see the M4 led is blinking green quite rapidly, M2 led is blinking red rather slow, M2 and M3 are always blue.
Thank you.
Craziflie 2.0 not respond to iOS client
Re: Craziflie 2.0 not respond to iOS client
OK, I seem to have found out the trick. Every time I restart the flie, I need to place it horizontally, only after I do that it will start to accept the command.
Is that something bug or maybe a safety precaution?
When you turn on the Crazyflie is does a number of self-tests on its sensors. You need to make sure it is horizontal and undisturbed during this process.
I've moved this thread to Crazyflie->Support forum.
