Pin 2,3 are used for the MPU. Is this just general Input/Output?
Pin 5,6 I configured as RCC but I'm not sure what tho set in HSE and LSE. {Disable, Crystal/Ceramic Resonator, BYPASS Clock Source}
Pin 20 Is this also just a General Input/Output?
Pin 34,36 are SPI2 but I have no idea what to set in Mode {Full-Duplex, Half-Duplex, Receive Only, Transmit Only}/{Master,Slave}
The 2nd Problem is the Clock Configuration. There are a lot of Options and I'm not sure what to set.
Thx for any help. Maybe you even also used the CubeMX and have some configuration files
