aerogel and Cylon connection problem
Posted: Thu Feb 19, 2015 4:55 am
Hello, I want to control CF 2.0 with aerogle and Cylon.
But both of them have a problem with connection.
I think this is about libusb problem.
This is my problem. and the code is https://github.com/alanshaw/node-crazyf ... r/index.js
and i try Cylon example code, but it also have same error. http://cylonjs.com/documentation/drivers/crazyflie/
C:\node\node-crazyflie-keyboard-master\node-crazyflie-keyboard-master>node index.js
hello, this is start point
create CrazyDriver
loaded library & module
C:\node\node-crazyflie-keyboard-master\node-crazyflie-keyboard-master\node_modules\aerogel\lib\usbstreams.js:30
this.endpoint.startStream(3, 64);
TypeError: Object #<InEndpoint> has no method 'startStream'
at ReadableUSBStream._read (C:\node\node-crazyflie-keyboard-master\node-craz
yflie-keyboard-master\node_modules\aerogel\lib\usbstreams.js:30:17)
at ReadableUSBStream.Readable.read (_stream_readable.js:340:10)
at ReadableUSBStream.Readable.on (_stream_readable.js:719:14)
at Crazyradio.setupRadio (C:\node\node-crazyflie-keyboard-master\node-crazyf
lie-keyboard-master\node_modules\aerogel\lib\crazyradio.js:120:8)
at CrazyDriver.findCopters (C:\node\node-crazyflie-keyboard-master\node-craz
yflie-keyboard-master\node_modules\aerogel\lib\crazydriver.js:39:20)
at Object.<anonymous> (C:\node\node-crazyflie-keyboard-master\node-crazyflie
-keyboard-master\index.js:9:8)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
Could you help me?
Thank you.
create CrazyDriver
Could you help me?
Thank you.
