				Flashing Red
				Posted: Tue Jan 06, 2015 12:12 am
				by espey
				I recently received a CF2, it flashes red on the test and the power button broke off. I'm not at the stage of putting on the propellers on, let alone fly it. After speaking to the manufacturer in China, they stated that I can send it back and they might provide a coupon to reimburse for the shipping. Personally, this is an offensive approach.
With this said, how can we go about getting this cool device off my desk into the air. Please help!
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 3:35 am
				by espey
				No response? Really?
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 7:28 pm
				by chad
				Which LED flashes red after self-test. How long, and at what frequency? Are you doing a hardware test with the battery connected or while plugged into USB? Do you have a Crazyradio dongle?
You
can use a piece of wire (or other metal object) to bridge the connections between the on/off button momentarily to turn on or off the Crazyflie. This will work fine in place of a power button. You can get
power buttons on the cheap and
with a soldering iron and a modicum of skill you can replace it.
You might want to try to update the firmware. You'll need to download the
direct firmware update (DFU) zip file and get the Crazyflie into DFU mode. To get it into direct firmware update (DFU) without a power button, you'll have to bridge the connection longer than just momentarily (much like holding down the on/off button). You can follow the instructions in the ReadMe.txt (in the zip file) to do the update. It will be a little challenging but that's part of the fun.
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 8:49 pm
				by espey
				M1 flashes red non-stop. It doesn't matter if the battery is the power source or USB.
Still waiting for the dongle to be shipped.
As far as updating, tried to install zadig_xp_2.1.1 (running on Win7) STM32 Bootlader, it states a success. But...when opening the flash_crazyflie.bat it shows failed.
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 9:39 pm
				by chad
				espey wrote:M1 flashes red non-stop.
As far as frequency goes, does the flash look like
this video...? (this is a self-test failure condition). If it does look like this, try powering it on again but don't disturb it during the self-test. Some sensors may be susceptible to movement during self-test and might indicate a failure state.
espey wrote:As far as updating, tried to install zadig_xp_2.1.1 (running on Win7) STM32 Bootlader, it states a success. But...when opening the flash_crazyflie.bat it shows failed.
I'm not a Windows user so I'm sorry that I can't be more help here but... If you're running Windows 7 shouldn't you be using the "
Windows Vista or later" Zadig driver?
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 9:57 pm
				by espey
				The video demonstrates a much faster flashing than mine. It appears to be the same speed as M2 in DFU mode.
I think the installed driver is correct but I tried both.
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 10:04 pm
				by chad
				If the M1 LED blinks continuously (like the
very end of this video), that's the heartbeat. It's correct behavior and your Crazyflie is alive.
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 10:08 pm
				by espey
				Great, we have a heartbeat! Now what?
				Re: Flashing Red
				Posted: Thu Jan 08, 2015 11:01 pm
				by chad
				espey wrote:Great, we have a heartbeat! Now what?
Put on the propellers and fly it?
You might want the take a look at the
"Getting Started" section of this blog post if you haven't seen all this info already.
If you want to update the firmware, try your Zadig install again
following the instructions here. Of course, make sure you really
do have the
right driver installed,
as specified on the Zadig site. Then, follow that ReadMe file in the DFU zip you downloaded.
Finally, use your
Android or
iPhone device to start learning how to fly while you wait for the Crazyradio PA dongle to arrive (which will make it much easier to fly).
