CrazyFlie RPi Image wont boot on model b+
I've downloaded the 0.3 image and used Win32DiskImager to write to an 8GB SD - then plugged it into a model B+
No boot - HDMI never outputs anything - LEDS on board are totally idle except for the red power light.
Should this work? Any image for the B should work for B+ right?
(Nothing wrong with the pi - other SD's boot).
Re: CrazyFlie RPi Image wont boot on model b+
Interesting. Maybe the version of Raspbian it's based on is too old for the B+...? I have a B+ but I haven't tried the 0.3 image on it yet. I'll give it a try later tonight and report back.
You can also just install the latest Raspbian image and add the Bitcraze stuff over it (which is basically all Bitcraze did). Those instructions might be a little outdated what with the new release and all so YMMV.
Someday I'll get a chance to make a blog post about the script I use to overlay the Bitcraze stuff on a Raspbian image. I basically just tar'd up the Bitcraze directories from the 0.3 install and created a bash script "installer" to untar them into the Raspbian install. It works fairly well and makes it easier to use a stock image. I just haven't had time to update it for 2.0 yet...
Here it is in the "code" section if you're curious and want to try it out. Save it as a shell script, make it executable, and run it on a stock Raspbian install. You gotta run it as root. Bear in mind, it's for Crazyflie 1.0 not 2.0 (yet)... No guarantees and no warranty, etc, etc...
#!/bin/bash
# Installed content Copyright 2011-2014 Bitcraze AB
# Installer script Copyright 2014 Chad Stanke
# This work is licensed under the Creative Commons Attribution-ShareAlike
# 4.0 International License. To view a copy of this license,
# visit http://creativecommons.org/licenses/by-sa/4.0/.
# WTF is this!? This adds the bitcraze stuff to a regular Debian Wheezy Raspbian
# image. You can take the default image and run this on it to get a headless
# crazyflie flight controller. The blocks of randomy looking text is gziped
# files and folders taken from the Bitcraze 0.3 Raspbian image at:
# https://github.com/bitcraze/bitcraze-raspberry-pi
# Then, we simply make some tweaks to get things like I want them (like moving the stuff in /boot to /etc).
# Simple, clean, and fast!
# install bitcraze RaspberryPi additions
BITCRAZE_USER_NAME=bitcraze
BITCRAZE_USER_PASS=crazyflie
if [[ $EUID -ne 0 ]]; then
echo "This script must be run as root" 1>&2
exit 1
fi
apt-get update
apt-get -y upgrade
apt-get -y install python-usb xboxdrv
useradd --create-home -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,netdev,input -p $(openssl passwd -1 ${BITCRAZE_USER_PASS}) ${BITCRAZE_USER_NAME}
# /boot/crazyflie - NOPE
# /etc/crazyflie
INSTALL_DIR="/etc/" # was /boot/ - need to fix up aliases pointing to /boot...
cat <<EOF | openssl enc -base64 -d | tar -xzpf - -C "${INSTALL_DIR}"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=
EOF
# /root/bin
INSTALL_DIR="/root/"
H4sIAILkHVMAA+3UTU+DMBgHcM58ime47DZLeY2HLTF62UU9eHe8FCGysUAxi5/e
sgw2dXOJCTPG/+9SoE/feNqG2ZJpPTMV33U3pfK53Dxzi3ueybnn2JrJTdtyNHL7
nlijrmRQEmllUcjv4k7V/1Ghyv86LNa2Z/Y2xqn8c8ff5d93VP7VF65RfzPa88/z
fzFgzRaoUj1LSIpKkjG8vnmc3d8ZNCEjiGNDl6lY6rTF6qpk7a6Jy1ca6SKvRFf/
kuV5kOc0vqJthJ5k+m8vE45oMhklqQjiXFRVP2OcOv+u7XXn37fUd27Zro3zfw4/
P/9VHRc0rinMZFQGb4JYWiwEa19Z81/l025v0ZSYXKz2dttlXjyTNR1xdYe03Yso
LWg4OBC8yuKjN80urKttlzNODvbUhn1YW+thdjuZR4E81HL+JbqZRzOJoWrWVao7
D9ceAAAAAAAAAAAAAAAAAACczTtDTFfHACgAAA==
EOF
# /etc/udev/rules.d
INSTALL_DIR="/etc/udev/rules.d/"
H4sIAEvkHVMAA+3TTUvDMBgH8J73KUqvWpu0TUoOPSgOT3OjL4LHdqk6GIukzRiI
393Ug2+wdWDxBf6/S8jzFB4anr8Q/vLuoankumlbvzKdartKd2fa2IIzDmLxOH49
ra8nieLIoSHlnFBCGHMIZSEljktGmn+Q6f/XdR2tVHfou6H+P5WXF/ltXkxnaeqZ
tvZO3fOiyPKnlbxpNlLpZ1ungrIPjYVW0iy7vpNYtjObX07tjXAe29tVNi8Xqfe4
Nvey2dpCVl6fpF7Qv2BQrzbB+8J5k+/NtwtDh+ZPfvuJ/zQh/F2tdlJvR438J0P5
pyx5yz8lff5Dxjjy/xOOyR+JWbMnfwkVxyS+X7GIE2QRAAAAAAAAAAAAAAAAAAAA
YHQvMxP62AAoAAA=
EOF
# /home/bitcraze
INSTALL_DIR="/home/bitcraze/"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EOF
chgrp -R ${BITCRAZE_USER_NAME} /home/bitcraze
# Finally, reload the rules and we're all good!
udevadm control --reload-rules
# Get the bitcraze source
su ${BITCRAZE_USER_NAME} -c "mkdir ~/projects"
su ${BITCRAZE_USER_NAME} -c "git clone https://github.com/bitcraze/crazyflie-clients-python.git ~/projects/crazyflie-clients-python"
su ${BITCRAZE_USER_NAME} -c "git clone https://github.com/bitcraze/crazyflie-firmware.git ~/projects/crazyflie-firmware"
# Fix up the links (since we moved our configs from /boot to /etc
su ${BITCRAZE_USER_NAME} -c "ln -sf /etc/crazyflie/controller.conf ~/controller.conf"
su ${BITCRAZE_USER_NAME} -c "ln -sf /etc/crazyflie/link.conf ~/link.conf"
su ${BITCRAZE_USER_NAME} -c "mkdir -p ~/projects/crazyflie-clients-python/conf/cache"
su ${BITCRAZE_USER_NAME} -c "ln -s /etc/crazyflie/input/ ~/projects/crazyflie-clients-python/conf/input"
exit 0
Yep. Sure enough my B+ doesn't boot from the 0.3 image either. Thanks for giving me a reason to open my B+ box though.
I'm going to try to install the latest Raspbian image and see if I can detail the steps necessary (using that script I posted) to get a headless Pi B+ ground controller running. I've used my Pi 'B' for the last 6 months with my CF1.0 and I love it! I haven't received my CF2.0 yet so I can't be of much help there right now.
I'll post back when I have a chance.
Ok. My script will work but you can't run with the latest cfclient. Unfortunately, as far as I can tell, python-sdl2 is not available in the Raspbian Wheezy repository. That's unfortunate because the head of master branch of crazyflie-client-python in Git requires SDL2 now. I logged a bug against it.
So, if you run my script and checkout the crazyflie-client-python to a specific revision, you can use RaspberryPi B+ for CF1.0 - not sure for 2.0 though (like I say, haven't got mine yet so I can't check it out)...
Anyway, here's the steps FWIW:
- Flash latest Raspbian image to SD card.
- Boot RaspberryPi B+ using said SD card.
- Get the script onto your RaspberryPi however you want: SSH, USB thumbdrive, SD Card reader, etc...
- Copy script to pi's home directory call it installcf.sh
- While logged in as 'pi', run the following in a command prompt:
cd chmod 755 installcf.sh sudo ./installcf.sh - Wait a while for apt-get updates
- Edit for your controller profile and link info
sudo su - bitcraze - Add your link info (i.e. radio://0/3/2M)
nano -wz link.conf - Add your controller info (i.e. PS3_Mode_2)
nano -wz controller.conf - Update (downgrade) cfclient to a usable state
cd ~/projects/crazyflie-client-python git checkout 97592cf2805ca79e0dfa496a20329ad831e2d03f - Reboot the RaspberryPi
exit sudo reboot - Finally, plug in your controller, turn on your Crazyflie, and plug in the Crazyradio.
Marcus (one of the Bitcraze guys) said they're working a Raspbian image right now so you should have a solution soon. Also, he mentioned that the SDL2 dependency could be installed via Python pip but, since I'm at work all day today, I haven't had a chance to try it out and capture the steps. I'll try if I have the time tonight. In any case, I think SDL2 on Linux has issues presently so it might just be a good idea to wait... Then again, I thought I saw a post from you saying your CF flew away!?!?
Bummer. Maybe this is all moot to you now.
Forgot about this thread!
Yes, my Crazyflie flew away a couple of days after posting that. Damn shame really. Not moot however! I have ordered 2 more just before xmas, they have supposedly shipped, I'm just waiting for the tracking number to be activated on SingPost.
Yes, you read that right - I ordered 2.. I really hope I don't have another flyaway, but I really want to hack this thing, so plan for the worst...
This is getting expensive
Thanks for the updates, I'll be looking forward to the updated image for B+
Hi Chad,
Thanks so much for posting the scripts and instructions. I ran your script, and followed the instructions but skipped step "Update (downgrade) cfclient to a usable state" and it worked perfectly. I now have a fully functioning pi controller, RPiB+/CF2/PS4/CrazyRadio.
Great work!!
Thanks,
Adam
Great work!!
Thanks,
Adam
Awesome! Happy to hear you're flying again!!
