Page 3 of 3
Re: How to Compiling CF's FW on win7 !
Posted: Mon Jun 03, 2013 3:57 am
by gl516
smokedasphalt wrote:Have you installed python2.7? Can you run the command python in your command prompt? If you can't, then please install python2.7 from here http://python.org/download/ and follow the instructions to set up the pythonpath from here http://www.anthonydebarros.com/2011/10/ ... windows-7/
yes ......i feel has been installed python2.7
phthon (command line)
Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
But how do I test in the MSDOS PYTHON is installed correctly!
Posted: Mon Jun 03, 2013 6:54 am
by gl516
Now compiled by the information below!
To: JoshLillie
To see your post also have same problem! Could you tell me you is how to compile successfully. The TKS!
Posted: Mon Jun 03, 2013 7:30 am
by smokedasphalt
It seems that you have not installed hg properly. Can you run hg in your command prompt and get this output?
Posted: Mon Jun 03, 2013 7:42 am
by gl516
smokedasphalt wrote:It seems that you have not installed hg properly. Can you run hg in your command prompt and get this output?
NO....According to 'hg' not internal or external command.Is not runnable program......
Good news ...COOL ........... I will "hg" PATH increase to the mercurial's path environment variable... tt's Test pass! Thank you guys for help.. TKS smokedasphalt .........tks !!!!
:D
Posted: Mon Jun 03, 2013 8:27 am
by smokedasphalt
gl516 wrote:Good news ...COOL ........... I will "hg" PATH increase to the mercurial's path environment variable... tt's Test pass! Thank you guys for help.. TKS smokedasphalt .........tks !!!!
:D
Awesome! Have fun :)
