Hi I am having a very similar problem but I am simply not able to figure out how to fix it. I have been trying for a long time to figure out how to fix it. I thought I installed the new firmware but I literally have no idea. I am running the client on a virtual windows machine that i have installed on my mac.
These are the errors that I am getting:
Error when starting log config [motors]: Block too large
Error when starting log config [Baro]: No more memory available
Error when starting log config [AltHold]: No more memory available
Any help would be greatly appreciated. Thank you so much!!!
Block too large
Re: Block too large
Did you flash the latest firmware in the Crazyflie following these instructions: http://wiki.bitcraze.se/doc:crazyflie:c ... bootloader ?
Re: Block too large
Don't be sorry! Everyone has a different learning curve. That's what forums are good for!!erlingrj wrote:I'm sorry, very unexperienced with programming, I finally figured out how to update the firmware on the crazyflie and now everything works perfect
