Hah, i was actually intending to do the same (visualization using d3).
For some reason, though, i got no control ever and telemetry only sometimes.
Still haven't tried Kikill's depo, though (too much stuff going on at work).
Did anyone get the Cylon Crazyflie adapter to work?
Re: Did anyone get the Cylon Crazyflie adapter to work?
I'm having the exact same issue with the exact same sporadic results listed below. Motors spin fine on power up and i see the green lights on both Crazyflie and Crazyradio but the motors never spin up. I was able to confirm that the telemetry from the onboard instrumentation is working thru cfclient.
any ideas?
any ideas?
orcinus wrote:Cylon uses aerogel.
Anyways, no luck there either, it's aerogel that actually hangs waiting for (something).
Didn't have much time to debug, unfortunately.
It finds the cf, gets the URI, then something in the connect method hangs.
The weird part is, the output/behaviour are not always the same.
Sometimes i just get:
Sometimes i get:Code: Select all
STATE: setup --> connected
I'll play a bit more with it the next weekend (hopefully that one will be free unlike the past fewCode: Select all
STATE: setup --> connected starting telemetry telemetry ready; elapsed= 439 { 'pm.state': { id: 1, type: 4, group: 'pm', name: 'state', fullname: 'pm.state' }, 'sys.canfly': { id: 2, type: 4, group: 'sys', name: 'canfly', fullname: 'sys.canfly' }, 'acc.x': { id: 3, type: 7, group: 'acc', name: 'x', fullname: 'acc.x' }, 'acc.y': { id: 4, type: 7, group: 'acc', name: 'y', fullname: 'acc.y' }, 'acc.z': { id: 5, type: 7, group: 'acc', name: 'z', fullname: 'acc.z' }, 'acc.zw': { id: 6, type: 7, group: 'acc', name: 'zw', fullname: 'acc.zw' }, 'acc.mag2': { id: 7, type: 7, group: 'acc', name: 'mag2', fullname: 'acc.mag2' }, 'baro.asl': { id: 8, type: 7, group: 'baro', name: 'asl', fullname: 'baro.asl' }, 'baro.aslRaw': { id: 9, type: 7, group: 'baro', name: 'aslRaw', fullname: 'baro.aslRaw' }, 'baro.aslLong': { id: 10, type: 7, group: 'baro', name: 'aslLong', fullname: 'baro.aslLong' }, 'baro.temp': { id: 11, type: 7, group: 'baro', name: 'temp', fullname: 'baro.temp' }, 'baro.pressure': { id: 12, type: 7, group: 'baro', name: 'pressure', fullname: 'baro.pressure' }, 'motor.m4': { id: 13, type: 6, group: 'motor', name: 'm4', fullname: 'motor.m4' }, 'motor.m1': { id: 14, type: 6, group: 'motor', name: 'm1', fullname: 'motor.m1' }, 'motor.m2': { id: 15, type: 6, group: 'motor', name: 'm2', fullname: 'motor.m2' }, 'motor.m3': { id: 16, type: 6, group: 'motor', name: 'm3', fullname: 'motor.m3' }, 'stabilizer.roll': { id: 17, type: 7, group: 'stabilizer', name: 'roll', fullname: 'stabilizer.roll' }, 'stabilizer.pitch': { id: 18, type: 7, group: 'stabilizer', name: 'pitch', fullname: 'stabilizer.pitch' }, 'stabilizer.yaw': { id: 19, type: 7, group: 'stabilizer', name: 'yaw', fullname: 'stabilizer.yaw' }, 'stabilizer.thrust': { id: 20, type: 2, group: 'stabilizer', name: 'thrust', fullname: 'stabilizer.thrust' }, 'altHold.err': { id: 21, type: 7, group: 'altHold', name: 'err', fullname: 'altHold.err' }, 'altHold.target': { id: 22, type: 7, group: 'altHold', name: 'target', fullname: 'altHold.target' }, 'altHold.zSpeed': { id: 23, type: 7, group: 'altHold', name: 'zSpeed', fullname: 'altHold.zSpeed' }, 'altHold.vSpeed': { id: 24, type: 7, group: 'altHold', name: 'vSpeed', fullname: 'altHold.vSpeed' }, 'altHold.vSpeedASL': { id: 25, type: 7, group: 'altHold', name: 'vSpeedASL', fullname: 'altHold.vSpeedASL' }, 'altHold.vSpeedAcc': { id: 26, type: 7, group: 'altHold', name: 'vSpeedAcc', fullname: 'altHold.vSpeedAcc' }, 'gyro.x': { id: 27, type: 7, group: 'gyro', name: 'x', fullname: 'gyro.x' }, 'gyro.y': { id: 28, type: 7, group: 'gyro', name: 'y', fullname: 'gyro.y' }, 'gyro.z': { id: 29, type: 7, group: 'gyro', name: 'z', fullname: 'gyro.z' }, 'vpid.pid': { id: 30, type: 7, group: 'vpid', name: 'pid', fullname: 'vpid.pid' }, 'vpid.p': { id: 31, type: 7, group: 'vpid', name: 'p', fullname: 'vpid.p' }, 'vpid.i': { id: 32, type: 7, group: 'vpid', name: 'i', fullname: 'vpid.i' }, 'vpid.d': { id: 33, type: 7, group: 'vpid', name: 'd', fullname: 'vpid.d' }, 'mag.x': { id: 34, type: 7, group: 'mag', name: 'x', fullname: 'mag.x' }, 'mag.y': { id: 35, type: 7, group: 'mag', name: 'y', fullname: 'mag.y' }, 'mag.z': { id: 36, type: 7, group: 'mag', name: 'z', fullname: 'mag.z' } } STATE: connected --> waiting).
