Logging Data from CFClient
Re: Logging Data from CFClient
Post by chad »
rgalvez wrote:What software should I use to send commands to the crazyflie?Pycharm?
If you want, you can simply write a python script in a plain text file and run it from the Terminal application:
python /path/to/script.py
The example scripts in the "examples" folder of the crazyflie-clients-python repository are good starters.
