Page 2 of 2
Re: How to use the breakout board
Posted: Fri Mar 16, 2018 7:35 am
by arnaud
A revision about the pulse: apparently the trig pulse should be asserted for ~10us. If this is mandatory, using a timer for generating the pulse is indeed required.
I have not looked in great details but I think you should be able to use the Timer 5 with one channel as output for the pulse and another channel as input for timing the echo. Timer 5 has two channels mapped on PA2 and PA3 port of the deck port.
One info if you stumble on the problem: the two timer 5 channels are channels CH3 and CH4 which is problematic for some case (like implementing pulse measurement, the timer is designed to have CH1/CH2 and CH3/CH4 to work as pair). In our LH implementation we used a XOR gate that is present in the timer to re-route CH3 to the internal CH1. See the initialization of LH: https://github.com/bitcraze/crazyflie-f ... der.c#L118. If my thinking is correct you will need to generate the pulse on CH4 and measure the echo from CH3 using the timer capture registers 1 and 2 for rising and falling edge (the way we do it in LH).
Posted: Tue Mar 20, 2018 7:45 pm
by matthieuleonie
Thank you so much! We'll try that :)
