only two tags range at the same time with TDMA
justinleeyang
Re: only two tags range at the same time with TDMA
Post by justinleeyang »
hi,
a issue, 26 means 480 slots, but how to calculate it?
I see the comment about "since the timer is running at ~64GHZ".
In theory you would calculate the frame frequency with 64GHz / 2^(n+m):
- n the number of bit per slot
- m the number of bit to encode the slot ID (2^m slot per frame).
And the slot frequency with 64GHz / 2^n.
The bug here is that 64e9 / 2^26 = 953Hz, the double! I have a +1 in most of these time calculation I think this is the source of the bug. 27 should have been the correct value.
By the way, is it working properly at 480Hz slot rate?
justinleeyang
hi, arnaud:
thanks your reply! I have understanded your method, 480 slots no problem, and I will add more tag to test.
Thanks for testing! I will test as well and fix the implementation.
We are having a demo at Maker Faire Berlin at the end of the week and it is really nice to find that now: we only have 2x2m to fly autonomously and having twice as much ranging will certainly help!
justinleeyang
Good luck for you, and wish that I will join the Maker Faire next year.
