Log and param could jus be disabled by not calling there init function. The same for the Deck drivers.
For debuging: the way this is supposed to work is that the symbols set by the linker should link to the start and end of the section that contains the log/param/deck structures. This is how they are accessed by the software at runtime.
Maybe you can try to ask on an ARM/Keil forum. The functionality you need to reproduce in keil is this part of the GCC linker script: https://github.com/bitcraze/crazyflie-f ... ld#L48-L62. You can see that I declare the symbols before and after including the section in the flash.
Compiling Crazyflie firmware in keil - linker section
justinleeyang
Re: Compiling Crazyflie firmware in keil - linker section
Got it! I will try.
