Did you add your driver to the Makefile and did you enable it by defining DECK_FORCE as described here: https://wiki.bitcraze.io/doc:crazyflie: ... mware:deck ?
If your driver is compiled it is going to be listed (if you add DEBUG=1 in tools/make/config.mk).
If you set DECK_FORCE you will see the initialization.
question about the Deck-driver structure
Re: question about the Deck-driver structure
Hello arnaud! I can't see the deck-driver initialization on my console! However, i have added the DECK FORce in my makefile. You can find attached a block of my makefile :
# Init
ifeq ($(F405), 1)
PROJ_OBJ = main.o platform_cf2.o
else
PROJ_OBJ = main.o
endif
# Drivers
PROJ_OBJ += led.o exti.o nvic.o
PROJ_OBJ += sensor.o
CFLAGS += -DDECK_FORCE=myIRSensorsRe: question about the Deck-driver structure
I have also this in my makefile and i have no rule to make target deck_digital.o needed by 'cflie.elf'. Stop.
# Expansion boards
PROJ_OBJ += exptest.o
PROJ_OBJ += deck_digital.o
PROJ_OBJ += deck_analog.o
PROJ_OBJ += deck.o
PROJ_OBJ += deck_info.o
PROJ_OBJ += deck_drivers.o
PROJ_OBJ += deck_core.o
PROJ_OBJ += deck_constants.oRe: question about the Deck-driver structure
This is strange, it should work.
I have made a small howto on the wiki: https://wiki.bitcraze.io/doc:crazyflie: ... deck:howto by following it you will get your code running in Crazyflie 2.0.
Hi Arnaud! thank you for your answers. In fact, I have followed your configuration as it should; However, i still can't screen my debug messages on the console and i don't know why! In other words, the driver is not configured and the code is never run!
Are you sure you are on the master branch with the latest commit from Github? I re-run everything from a clean tree to write the documentation so from this state it should work.
/Arnaud
/Arnaud
