Compiling the firmware on Windows
Re: Compiling the firmware on Windows
Why aren't you doing it from the MinGW /msys shell?
Ok all is working now, I had only set the "PythonPath" variable and not the system path for python. I also had a conflict with the "Yargo" tool set which I removed from my machine. So I am able to build the firmware now and it is independent of the minig shell. Thanks for all the replies!
Damn, I saw that you had phython/lib instead of phyton and already typed that into my comment, but than thought it looked like you where able to run phyton, so deleted that
- Good that it works now for you.
