Re: Where are the latest binaries?
Posted: Fri Jan 16, 2015 3:28 pm
I can also confirm that the Android Client won't work either. Though, in that case everything seems to connect as it should until the CR quickly disconnects as soon as I push forward on the thrust.
Meanwhile, the CFClient won't connect to the CR at all and this is the debug output-
Cfclient version: 2014.12.1-14-g927af48
System: linux2
Interface status
UsbCdc: No information available
serial: None
radio: Crazyradio version 0.53
udp: None
Crazyflie
Connected: None
Firmware: None
Sensors found
Sensors tests
