Re: Crazyflie 2.0 I2C FAILURE
Posted: Mon Mar 09, 2015 1:47 am
I'm getting a similar error:
With me, it worked fine when I first started it up (albeit some balance issues that could be contributed to pilot error). I ran it off the iOS app on my iPhone 5s, then switched to using Crazyradio/Windows Client (on Windows 7 64-bit), with a Logitech 3D Pro joystick for controls. Several times both with the app and joystick controllers, it would collide or end up upside down and would start blinking; i was able to fix by d/c'ing, power-cycling the quad, and r/c'ing. However, whatever happened the last time has caused it to do this every restart.
The only other thing I have noticed is that when it spins up during the POST, the M1 prop doesn't seem to spin as fast as the others. However I can find no damage to the connectors nor anything that might suggest the prop or engine are having issues.
My folks got me the CF2 for my birthday after I bricked the CF1 they got me for Christmas before I could even fly it (sodering accident destroyed the PCB), I'd rather not have to tell them this one's FUBAR too.
EDIT: Using the schematics and placement diagram I was able to locate the component MPU9250 (labeled U9 on the placement diagram). It's a small square chip, located on the top of the board, just inside the expansion board pin strip on the left-hand side - right next to a symbol that looks like it's supposed to point out where the axis directions are.
I have absolutely no bloody clue what that particular component does, but what I DO know is that after I put a small amount of pressure on that chip with my thumb, the CF2 started passing POST again.
So yeah, most likely there are components that are not soldered well on the CF2 (my folks ordered it from Seeedstudio so more than likely it's the same issue everyone else is having with them). For now I want to try and run some additional tests for the stability issues I'm having.
SYS: Crazyflie is up and running!
SYS: Build 164:0dbbb77772a9 (production1.1) CLEAN
SYS: I am 0x3132383231334712230041 and I have 1024KB of flash!
I2CDEV: Error callback nr: 1024
IMU: MPU9250 I2C connection [FAIL].
IMU: AK8963 I2C connection [FAIL].
IMU: LPS25H I2C connection [FAIL].
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
OW: Found 0.
30 78 42 43 0 46 0 0 0 0 0 0 0 0 0 73
Status 0
0 0 73
Status 0The only other thing I have noticed is that when it spins up during the POST, the M1 prop doesn't seem to spin as fast as the others. However I can find no damage to the connectors nor anything that might suggest the prop or engine are having issues.
