It's basically a node-usb implementation of the crazy radio config specs here: https://wiki.bitcraze.io/doc:crazyradio ... ry_ard_arc
I wanted something a little faster and easier to manage than the chrome example, no cylon.js, no chrome, etc. So far so good, but I'm having issues with the START_SCAN_CHANNELS.
For some reason, my control transfer always times out and leaves the dongle in bad state (needs to be unplugged).
Any idea what's wrong with this code?
device.controlTransfer(0x40, 0x21, low, high, new Buffer(high - low), cb);If you have some node savvy you can download the repo and run the tests pretty easily. The scan test is commented out tho.
