printenv looks like:
TERM_PROGRAM=Apple_Terminal
M2=/opt/maven/bin
TERM=xterm-256color
SHELL=/bin/bash
TMPDIR=/var/folders/rm/yzfbkl4j7k19jxgzrxb27dbw0000gn/T/
Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.LC8ulV9Yni/Render
TERM_PROGRAM_VERSION=361.1
OLDPWD=/Users/ahuber/Documents/Projects/crazyflie/crazyflie-firmware-2015.08.1
TERM_SESSION_ID=1B4FB4E1-3C2C-4F7F-9330-9C5FF929F420
USER=ahuber
SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.xYiKWDcKMr/Listeners
__CF_USER_TEXT_ENCODING=0x1F5:0x0:0x3
PATH=/Users/ahuber/Downloads/GCC-ARM/gcc-arm-none-eabi-4_9-2014q4/bin:/Applications/Xcode.app/Contents/Developer/usr/subversion-1.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/MacGPG2/bin:/opt/maven/bin
JAVA_HOME=/Library/Java/JavaVirtualMachines/jdk1.7.0_76.jdk/Contents/Home
LANG=de_DE.UTF-8
XPC_FLAGS=0x0
XPC_SERVICE_NAME=0
M2_HOME=/opt/maven
HOME=/Users/ahuber
SHLVL=1
LOGNAME=ahuber
DISPLAY=/private/tmp/com.apple.launchd.q6nLt6z8vo/org.macosforge.xquartz:0
SECURITYSESSIONID=186a7
PREV_PATH=/Applications/Xcode.app/Contents/Developer/usr/subversion-1.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/MacGPG2/bin:/opt/maven/bin
SVN_HOME=/Applications/Xcode.app/Contents/Developer/usr/subversion-1.6/bin
_=/usr/bin/printenv
Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/Users/ahuber/Downloads/GCC-ARM/gcc-arm-none-eabi-4_9-2014q4/bin/../lib/gcc/arm-none-eabi/4.9.3/lto-wrapper
Target: arm-none-eabi
Configured with: /Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/src/gcc/configure --target=arm-none-eabi --prefix=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native --libexecdir=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/lib --infodir=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/install-native/arm-none-eabi --build=x86_64-apple-darwin10 --host=x86_64-apple-darwin10 --with-gmp=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-mpfr=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-mpc=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-isl=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-cloog=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-libelf=/Users/build/GCC-4-9-build/gcc-arm-none-eabi-4_9-2014q4-20141203/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-lstdc++ -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,armv7-r
Thread model: single
gcc version 4.9.3 20141119 (release) [ARM/embedded-4_9-branch revision 218278] (GNU Tools for ARM Embedded Processors)
