Hi
I received new crazyfile 2.0 .. assembled it...VM up and running. ..ps3 controlled..yesterday all was well...now when I give command via ps3 controller crazyfile shut off....when I start self test is done. ..I connected crazyfile to power supply and gave command it doesn't shut off...is it a battery issue.?
						Problem to take off(battery problem. ?)
Re: Problem to take off(battery problem. ?)
Got it running
Hi!Prashant wrote:Hi
Happy to hear you got it running. Can you post back what you did so that you might help other in your situation..? Did you simply upgrade the firmware? The shut-off issue you write about sounds like something that was solved a while ago...
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
