I have the same problem as BlitzProgrammer: the program can't find the log module. Feedback:
File "escape.py", line 34, in <module>
from cfclient.utils.logconfigreader import LogConfig
ImportError: No module named cfclient.utils.logconfigreader
How do I fix this?
Programmable Flight Demonstration
Re: Programmable Flight Demonstration
qubitter, I had the same problem. Change the following snippet
from
to
from
import time, sys
from threading import Thread
#FIXME: Has to be launched from within the example folder
sys.path.append("../lib")
import cflib
import logging
logging.basicConfig(level=logging.ERROR)Code: Select all
import time, sys
import cflib
import logging
