Hey guys, I've been training myself to be a better pilot and had an idea...
I've mastered movement without using yaw and i'm currently learning to fly in small circles using a low roll/pith setting and fast yaw.
The hardest thing for me is keeping the thrust steady whilst operating the pitch and yaw.
I wonder if anybody feels up to the task of implementing some code where a push forward and release of the thrust + axis would "lock" the CF at that thrust, meaning you would push forward then let go of the axis to hold a steady thrust. to increase you push forward again or to decrease you push back on the axis...?
Any thoughts?
Cab
Simulation of a non spring return thrust axis
Call_me_a_Cab
- Member
Greensprings
- Member
Re: Simulation of a non spring return thrust axis
maybe just a dampner, where if you hold down a button it adds a delay to thrust changes
