I have found two bugs in the Python client as follows:
1. When the Crazyflie python client is run in VM 0.6, the log blocks checkmarks are always checked. The on/off function works -- the checkmarks just don't get unchecked. Note that I have performed a software update in the VM 0.6.  The client works fine on a Mac.
2. For the plotter tab, X axis, only samples is checked. How do I select range, seconds or manual?
