I am a student with just little Unix and programming experience.
I'm trying to flash the crazyflie (1.0) firmware with an Debugger from SEGGER, "j-link EDU".
I'm using the Bitcraze VM 0.6 an installed the J-Link Software for Linux 32bit. https://www.segger.com/jlink-software.html
After installation I tried to flash it in Eclipse ...
-> Make Target -> crazyflie-firmware -> Flash using debugger
... error!
Console:
22:42:19 **** Build of configuration Build (GNU) for project crazyflie-firmware ****
make flash
openocd -d2 -f interface/stlink-v2.cfg -f target/stm32f4x_stlink.cfg -c init -c targets -c "reset halt" \
-c "flash write_image erase cflie.elf" -c "verify_image cflie.elf" -c "reset run" -c shutdown
Open On-Chip Debugger 0.8.0 (2014-05-10-23:21)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
debug_level: 2
Info : This adapter doesn't support configurable speed
Error: open failed
in procedure 'transport'
in procedure 'init'
Makefile:268: recipe for target 'flash' failed
make: *** [flash] Error 1
22:42:19 Build Finished (took 305ms)
