hi,
I have a wireless xbox360 controller and I'm struggling to connect it to my PC (windows) , please help.
I have no experience with Xbox/PS but I thought it would be possible to connect any of those controllers to my PC wirelessly (via BT). I have no other wireless adapter or cable unfortunately for the controller. BT is running fine in Windows but just can't find the controller. CFClient doesn't recognize any input device.
This is where I'm stuck : http://wiki.bitcraze.se/projects:crazyf ... putdevices
The input-device needs to be recognized by the host operating system. This means that it should be seen in the operating system and be usable in other applications or utilities.
It would really help if someone can point me in the right direction. I couldn't find any other info in wiki in how to do this, maybe it's basic but I can't just figure it out.
I'm looking hungry at my CF 2.0.
thanks a lot. g.
xbox 360 to pc
Re: xbox 360 to pc
Done a little bit of digging and looks like the wireless controllers communicate with the XBox 360 using a proprietary RF protocol, and not Bluetooth, so the Bluetooth module built into the PC won't help.
I can either use a wireless controller + receiver or use a USB controller (wired).
I've been misguided by this wiki article http://wiki.bitcraze.se/projects:crazyf ... controller
Win7 BT + Xbox 360 = Works .. or maybe I misread it. Maybe someone cares to explain.
I'm curious how is it exactly for the PS3 controller.
thanks.
thanks.
Re: xbox 360 to pc
I'm sorry I can't speak much on the Windows side of things but my PS3 controller works fine over Bluetooth on my Mac - nothing extra needed...cfuser wrote:I'm curious how is it exactly for the PS3 controller.
According to this article on WikiHow you need the Motioninjoy driver for PS3 to work on Windows...
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
Re: xbox 360 to pc
XBox controllers will only work with a USB cable.
I just went out and bought a PS4 DualShock4 connected it via bluetooth to a Windows 8.1 machine and boom. done. Thats what I would suggest. Cables suck.
Re: xbox 360 to pc
You need a usb-to-rf dongle in order to use the xbox 360 wireless controller with a PC.
I bought a knock-off from eBay, which works OK, since the 'Official' one cost more then I wanted to spend.
Re: xbox 360 to pc
I have an xbox 360 controller. I plug the controller and its receiver in via 2 USB ports - to a Windows 7 machine. Win7 recognizes the controller - confirmed by running joy.cpl. After launching CF PC Client, the xbox 360 controller doesn't show up in the list of controller devices.atomicdog wrote:You need a usb-to-rf dongle in order to use the xbox 360 wireless controller with a PC.
How did you make it work?
Re: xbox 360 to pc
There has been a gamepad bug on the windows build at some point, you can try a newer build than the release. See my answer to this ticket: https://github.com/bitcraze/crazyflie-c ... issues/257
Re: xbox 360 to pc
Eureka!!! Thank you, Arnaud!!!arnaud wrote:Hi,
