Beginner question
Re: Beginner question
You open cmd.exe, in the upcoming black terminal window you change directories to wherever you downloaded pyusb to (e.g. "cd /folder/where/setup.py/is"). Once you are there you can type the command mentioned above "python setup.py install".
Thank you a lot.whoenig wrote:You open cmd.exe, in the upcoming black terminal window you change directories to wherever you downloaded pyusb to (e.g. "cd /folder/where/setup.py/is"). Once you are there you can type the command mentioned above "python setup.py install".
I used your method and succeeded to run the setup.py of pyusb.
BUT, still can't run the setup.py of client...
The client does not need to be installed. You should just be able to execute "python cfclient.py".
