I made a very simple python program that simply turns on thrust to get the crazyflie in the air, and then uses the hover functionality to enable hover mode. I looked extensively at the way hover was implemented in cfclient source code, and attempted to mimic this functionality. The hover is set as such:
cf.param.set_value("flightmode.althold", "True")Code: Select all
import sys
sys.path.append("../lib")
import cflib.crtp
import time
# Initialize the low-level drivers (don't list the debug drivers)
print "Scanning interfaces for Crazyflies..."
available = cflib.crtp.scan_interfaces()
print "Crazyflies found:"
for i in available:
print i[0]
if len(available) > 0:
# Create a Crazyflie object without specifying any cache dirs
cf = Crazyflie()
def handle_connected(link_uri):
print "Connected to %s" % link_uri
print "Sending thrust 45000"
cf.commander.send_setpoint(0, 0, 0, 45000)
time.sleep(0.75)
print "Stopping thrust; hovering"
cf.commander.send_setpoint(0, 0, 0, 0)
def close_link():
print 'Closing'
time.sleep(0.1)
cf.close_link()
# Connect some callbacks from the Crazyflie API
cf.connected.add_callback(handle_connected)
link_uri = available[0][0]
print "Connecting to %s" % link_uri
# Try to connect to the Crazyflie
cf.open_link(link_uri)
# Variable used to keep main loop occupied until disconnect
is_connected = True
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
close_link()
else:
print "No Crazyflies found, cannot run example"
[957179][Stabilizer]: {'altHold.target': 33.872318267822266, 'altHold.err': 0.1075897216796875}
[957279][Stabilizer]: {'altHold.target': 33.82230758666992, 'altHold.err': 0.11747360229492188}
[957379][Stabilizer]: {'altHold.target': 33.77229690551758, 'altHold.err': 0.11321258544921875}
[957579][Stabilizer]: {'altHold.target': 33.67227554321289, 'altHold.err': 0.3401451110839844}
[957679][Stabilizer]: {'altHold.target': 33.62226486206055, 'altHold.err': 0.3916740417480469}
[957779][Stabilizer]: {'altHold.target': 33.5722541809082, 'altHold.err': 0.3349266052246094}
[957879][Stabilizer]: {'altHold.target': 33.52224349975586, 'altHold.err': 0.3975334167480469}
[957979][Stabilizer]: {'altHold.target': 33.472232818603516, 'altHold.err': 0.43831634521484375}
[958179][Stabilizer]: {'altHold.target': 33.37221145629883, 'altHold.err': 0.5722694396972656}
[958279][Stabilizer]: {'altHold.target': 33.322200775146484, 'altHold.err': 0.6295738220214844}
[958379][Stabilizer]: {'altHold.target': 33.27219009399414, 'altHold.err': 0.6853408813476562}
[958479][Stabilizer]: {'altHold.target': 33.2221794128418, 'altHold.err': 0.699859619140625}
[958579][Stabilizer]: {'altHold.target': 33.17216873168945, 'altHold.err': 0.7846832275390625}
[958679][Stabilizer]: {'altHold.target': 33.12215805053711, 'altHold.err': 0.7600898742675781}
[958779][Stabilizer]: {'altHold.target': 33.072147369384766, 'altHold.err': 0.7624588012695312}
[958879][Stabilizer]: {'altHold.target': 33.02213668823242, 'altHold.err': 0.7686080932617188}
[958979][Stabilizer]: {'altHold.target': 32.97212600708008, 'altHold.err': 0.8769187927246094}
[959079][Stabilizer]: {'altHold.target': 32.922115325927734, 'altHold.err': 0.9493331909179688}
[959179][Stabilizer]: {'altHold.target': 0.0, 'altHold.err': 0.0}
[959279][Stabilizer]: {'altHold.target': 0.0, 'altHold.err': 0.0}
... etc.
Thank you!
