MPU6050: Self test acc Y [FAIL] - motor problem?
tomgilbert
Post by tomgilbert » Tue May 07, 2013 8:08 pm
I seem to have broken something already...DOH!
Crazyflie has been flying pretty well for a couple of days, although never yet hovering *exactly* in one place when thrust applied, always some small amount of bias that needed to be compensated for. Significant amount of crashing going on (!) since a challenge to keep in a small area as a result (ok, pilot error), but has survived well so far.
Tonight something has happened so that the self test on start fails. All props appear to turn, but the test then fails with the red LED flashing 5 times quickly. Is this something that can be fixed by replacing a motor? Some of the white wire plastic covering to motor M4 has been pierced in a rough landing, but I think the electrical connection is still fine.
Console reports (first showing a success from earlier, then a failure):
SYS: Crazyflie is up and running!
SYS: Build 31:ba1d111112ad (2013.4) CLEAN
SYS: I am 0x871149505456854966BFF50 and I have 128KB of flash!
IMU: MPU6050 I2C connection [OK].
IMU: HMC5883 I2C connection [OK].
IMU: MS5611 I2C connection [OK].
MPU6050: Self test [OK].
HMC5883L: Self test [OK].
MS5611: Self test [OK].
MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0
idhorst
Re: MPU6050: Self test acc Y [FAIL] - motor problem?
Post by idhorst » Tue May 07, 2013 8:24 pm
Didn't even get to fly it yet and have a similar problem.
SYS: Build 26:5f65b66e004d (Production-V2) CLEAN
SYS: I am 0x8720432953568549672FF54 and I have 128KB of flash!
MPU6050: Self test gyro X [FAIL]. low: 10.0, high: 105.0, measured: 0.0
Although I haven't connected a controller yet...
Post by tobias » Wed May 08, 2013 10:08 am
We have actually never experienced that the MPU6050 breaks but unfortunately it looks like it in these cases. To make it worse the Crazyflie wont be able to fly with a broken Y Gyro. Before we assume that though I would like you to do a test.
Turn on the Crazyflie then start slowly moving it around. Connect to it and send me the same command prompt output. If the Y output still measures 0.0 then it is probably broken. It is possible to replace it but that requires good soldering skills and a hot air station.
We will take this discussion up with Seeedstudio and get back to you guys if they really are broken.
tomgilbert
Post by tomgilbert » Wed May 08, 2013 12:49 pm
Thanks for getting back. In my case the problem seems to have resolved itself somehow. I've turned the crazyflie on and off at least 5 times today and each time a normal startup is reported:
The only issue I have at the moment is that on launch (touching just thrust) the copter won't ever go straight up & then down, it always drifts in a direction & I have to try and compensate with the controller to keep it in a small area. I haven't yet worked out if the drift direction is always consistent (quite hectic indoors!).
I guess I need to read in more detail everything you guys have posted about controller configuration (& trim) as well as check all motors to check for bent axles & propeller balance.
[controller is a Saitek Cyborg V.1 Game Pad]
Great fun, though!
idhorst
Post by idhorst » Wed May 08, 2013 7:33 pm
I still have the Gyro X fail message. Flashed the latest firmware but to no avail. Hope you can do something about it.
ng!
marcus
Post by marcus » Wed May 08, 2013 8:42 pm
Hi idhorst,
tobias wrote:Turn on the Crazyflie then start slowly moving it around. Connect to it and send me the same command prompt output. If the Y output still measures 0.0 then it is probably broken.
Could you try this and post the output. It's important that you start moving it just after you power it on.
/Marcus
idhorst
Post by idhorst » Sun May 12, 2013 9:31 am
I did as you instructed but the console message remains the same:
ng!
Did it a couple of times and the only thing that changes is the first line (ng!).
Post by tobias » Mon May 13, 2013 4:10 am
The MPU6050 is probably broken or the soldering has cracked. Can you begin by emailing Seeedstudio support about this and we will take it from there?
bkolb
Post by bkolb » Tue May 14, 2013 9:30 pm
I have a similar problem:
SYS: I am 0x8714365554568549679FF50 and I have 128KB of flash!
MPU6050: Self test acc X [FAIL]. low: 0.300000, high: 0.949999, measured: 1.71777
I guess the root cause is the same?
Should I mail to Seedstudio as well?
Cheers,
Bernd
Post by tobias » Wed May 15, 2013 6:39 am
If it doesn't report 0.0 it can be because that the Crazyflie was moved to much during self test. Try putting it on a stable surface and power it on. Do you get the same result?
