I apologise for the poor quality and the huge image size. I cannot see any visible shorts or anything where it shouldn't be.
Advice?
Cheers
Okay. If I hit the on/off switch the 3 other motors turn on and do their small movement. After that m3 is moving slightly slower than before ( probably because the rest of the board is now running). If I have the flie plugged in via USB and add the battery, it will continue to spin even after the battery is removed although at a much lower speed.doddz wrote:Does M3 stop at all or continue running constantly (maybe at different speeds)?
Sent from my HTC One using Tapatalk
