STEP 1:
Gather all the necessary tools:
- Vernier caliper
- sewing needles in as wide a range of sizes as possible
- two magnets (the two white cylinders in the photo - you can use any suitably small magnet with at least two flat surfaces)
STEP 2:
Find a needle you can barely get through the propeller shaft hole. If you're worried about loosening up the hole too much, or can't find a needle of a suitable diameter, just find one you can put the propeller on snugly with the pointed tip sticking through at least a few millimeters (as depicted).
Note: The needle MUST be straight! Or as straight as you can find.
STEP 3:
Put one magnet on each caliper jaw as depicted - try to get them as level as possible and as stable as possible.
Now comes the fun part.
STEP 4:
Put the needle with the propeller between the two magnets and let it stick to one of them with the pointy tip.
STEP 5:
Close the caliper jaws slowly until the needle "snaps" to the opposite magnet.
When it does, stop closing the jaws and open them back up a VERY VERY tiny amount.
STEP 6:
Now carefully nudge the needle back towards the pointy end magnet. It should snap there and stay there.
If it doesn't, open the jaw a slight bit more.
Start balancing!
The needle should now be suspended between the two magnetic fields with extremely low friction (because it's resting on the pointy end, with minimum force). The friction will be so low that even your normal breath might cause the propeller to rotate. Which is exactly what we're after.
Find a room with the least amount of draft and start balancing!
I recommend using tiny dots of nail polish or paint, as the Crazyflie propellers are simply too tiny and finicky for masking tape.
