I have seen the "debug://0/0 - Debugdriver for UI testing" only one time in the client, (i can't remember when and how)
but now, when i pluging the crazyradio and pressing the scan button, i can see nothing,
is it something wrong with the crazyradio or other problems ?
(the crazyradio can be recognized by the system in VM )
[SOLVED]debug://0/0 - Debugdriver for UI testing
Re: debug://0/0 - Debugdriver for UI testing
The debug driver has been removed by default to limit confusion. It is only intended to test the client software, if you want it back you can re-enable it by manually editing the config.json file.
Do you see that the radio is found in help/about/debug?
Is the serial:None right?arnaud wrote:The debug driver has been removed by default to limit confusion. It is only intended to test the client software, if you want it back you can re-enable it by manually editing the config.json file.
Cfclient
Cfclient version: 2013.11-beta1
System: linux2
Interface status
serial: None
radio: Crazyradio version 0.52
udp: None
Crazyflie
Connected: None
Firmware: None
Sensors found
Sensors tests
Is the Crazyflie running as it should? The Crazyradio seam to be working. When you press connect button does the red LED on the Crazyradio blink?
i solved all the problems, i understand finally, i have flashed the cflie.bin without the crazyflie bootloader by jtagtobias wrote:Is the Crazyflie running as it should? The Crazyradio seam to be working. When you press connect button does the red LED on the Crazyradio blink?
thank you tobias, thank you arnaud.
