Keil gcc compatible version of crazyflie_firmware
Re: I made a keil gcc compatible version of crazyflie_firmwa
Add cloader support
I assume that all that is necessary is to get the new scatter file from your github account?
Thank you very much for your work!
yes, just get scatter file and set the options to use it.DerShu wrote:I assume that all that is necessary is to get the new scatter file from your github account?
Re: Keil gcc compatible version of crazyflie_firmware
2013.12.14
commit 7aa4f06c551ad9a1969158d98781d765ac0fb6e7
Fix address bug in log/param module
Hello, Im trying to compile your project on my Keil uvision4 and 5 but on both of them I have some error. Uvision 4 says "port.c: Internal fault: [0xafc2db:400524]" and uvision 5 ".\keil_bin\keil.axf: error: L6050U: The code size of this image (42380 bytes) exceeds the maximum allowed for this version of the linker." So can you tell what version do you use? or what can I do to compile it on my comupter. Thanks for help
Edit:
Ok I fixed port.c: Internal fault in keil uvision 4 but sill I cant compile the source. The problem is in code size limitation ".\keil_bin\keil.axf: error: L6050U: The code size of this image (42380 bytes) exceeds the maximum allowed for this version of the linker".
Seems that you guys are using full versions of keil. Do you know what can I do to compile it? Is there any student licence or any other way to compile ?
Thanks
Edit:
You need full version of Keil. And that's why open source projects use GCC and linux environment. (free!)
