Inflight socket for extention port.
Anyone found some good parts for the extention socket to use in flight. ie remove the need to solder stuff directly without adding a lot of weight.
I guess a pin array would be best. (not sure of the dimentions.) but what about a light connecter?
I do not want to add payload but would like to remove HW easily.
Also need to be relativly cheap.
Re: Inflight socket for extention port.
OK, RTFM with regards to the dimentions.
http://wiki.bitcraze.se/projects:crazyf ... ion_header
Ok, I looked through my spairs and came across the pin headers for the expantion port. I guess its provided for JTAG debug but I can use it for the SPI expantion, which is what I want.
Yes, that's the idea of it but if you will do development you might need the JTAG as well or? The holes are designed to fit 1.27mm headers which comes in a lot of flavours.
Still not found a good part to connect onto it, small light available cheaply in low numbers.
I don't want to perminently solder a payload as it is experimental.
I now have a spare, could end up fitting both.tobias wrote:Yes, that's the idea of it but if you will do development you might need the JTAG as well or? The holes are designed to fit 1.27mm headers which comes in a lot of flavours.
Thanks, this is great. The findchips site is very useful, never seen it before. Harwins part numbers are way too flexable and finding a stockest is dificult. But the parts you have found look ideal and look to be available.
I'm thinking about fitting 2x5 pin header on reverse of the board and using a 2x5 female with wires soldered on it (dispite it being a PCB part.)
I think a connector on the component side would foul the battery too much.
Having the pins on the bottom could be a shorting hazard, although the bare board as it is is not without it's risks. I will look to order the parts and make the desision before fitting. May have to make up an order of other stuff to dull the shipping cost pain.
![Image](http://farm8.staticflickr.com/7387/9672498327_80bc2744aa.jpg)
P1040666 by billybag2, on Flickr
I got an extra pin header off ebay. Forgot one was with the flie. Ordered three X M50-3000545 from RS (UK) 6810692. I though the sockets would wiegh more but each part is about 0.17gms each. Also ordered some 30awg single core "wrapping" wire, which I hope to solder.
I think I will mount the socket under the flie. This gived good access for what I want to do, will be short resistant, and will not foul the battery.
Just to recap I am looking for inflight SPI . So I think the 10 way will be fine. I can choose to root JTAG/I2C upward later if required.
Nice! I'm getting really curious about what you are doing. Want to share? or maybe it is classified... ![:-) :)](./images/smilies/icon_e_smile.gif)
http://forum.bitcraze.se/viewtopic.php? ... t=10#p3389
Still a lot of potential show stoppers. Thats the main reason for a plug/socket.
