I realized I've been hijacking Another thread on here about using a camera on the Crazyflie, and thought I probably should make my own thread for it.
For previous info that I have been posting, check here!
http://forum.bitcraze.se/viewtopic.php?f=6&t=5&start=20
In short,
I have added this transmitter:
As well as a camera to the crazyflie, keeping in mind the voltage requirements, as well as the weight requirements - the Crazyflie can lift a max of around ~6grams in its stock configuration, and at that weight it's flight time is drastically lower.
The transmitter: http://www.fpvhobby.com/180-4-ghz-nano-size-vtx.html
The Camera: http://www.fpvhobby.com/63-1-gram-nano- ... 80tvl.html
After much testing, I started to have success in sending a video signal wirelessly
The wiring description which I should wikify at some point:
http://forum.bitcraze.se/viewtopic.php?p=2673#p2673
Video of the setup and how it's been done
http://www.youtube.com/watch?v=Zps4C9ko-dU
