With a fully charged battery and no indication of packets lost - The throttle will drop in value varying from the actual setting to half throttle to zero then come back up again.
I've upgraded, downgraded and upgraded again the firmware. I have changed the radio channels from low to high values. I've varied the bandwidth too. 250K-1M and 2M. I tried varying the slew. The same thing happens. I fly in Normal mode. I push the throttle the motors accelerate to the expected setting then in a few seconds the throttle will begin to variably fluctuate between the desired setting to zero without any user input.
See Youtube: http://www.youtube.com/watch?v=qCgvTiiCU34
Reminder: I have changed the firmware. I've changed channels and bandwidths to eliminate conflict with WiFi and other radios. In the video I am not varying the throttle after I have set it to approximately 50%. The variation of throttle seen in the video is the event that prohibits flying.
What could be the cause?
