FaceDetection Example
Hi, are we able to run the face detection example on the Bitcraze VM work environment? If so, how should I do it?
Re: FaceDetection Example
Hi! please see these instructions. https://www.bitcraze.io/documentation/r ... detection/
In the make file you need to uncomment the two defines as indicated at the bottom of the instructions. We will need to update the text as both streamer and camera should work in SDK 3.8
It works now! However, the stream image is upside down somehow. Is there a way to fix that?
Awesome!
yeah the upside down image was an issue but that should actually be fixed now since this issue: https://github.com/bitcraze/AIdeck_examples/issues/51
are you sure that you have pulled the latest changes of the AIdeck_examples repo?
I might not have done that yet. How should I pull the latest AIdeck_examples again?
Probably a 'git pull origin master' will suffice. But if you did a lot of changes to the code already, you can also just try a new git clone of the repo
