Problem uploading the trajectory to the autonomous_sequence_high_level.py.
rago7
Post by rago7 »
I'm trying to run the autonomous_sequence_high_level.py with a polynomial trajectory generated with the uav_trajectory, but when I run the code I get the next error:
Connecting to radio://0/80/2M
Connected to radio://0/80/2M
Uploading data
  File "autonomous_sequence_high_level.py", line 221, in <module>
    duration = upload_trajectory(cf, trajectory_id, figure8)
  File "autonomous_sequence_high_level.py", line 172, in upload_trajectory
    upload_result = Uploader().upload(trajectory_mem)
  File "autonomous_sequence_high_level.py", line 84, in upload
    write_failed_cb=self._upload_failed)
TypeError: write_data() got an unexpected keyword argument 'write_failed_cb'
I have checked the lenght of the trajectory and everything seems fine, any idea of how to correct this error?
The trajectory used is the following:
# Duration,x^0,x^1,x^2,x^3,x^4,x^5,x^6,x^7,y^0,y^1,y^2,y^3,y^4,y^5,y^6,y^7,z^0,z^1,z^2,z^3,z^4,z^5,z^6,z^7,yaw^0,yaw^1,yaw^2,yaw^3,yaw^4,yaw^5,yaw^6,yaw^7
figure8 = [
[4.000000,0.589063,0.000000,-0.000000,-0.004911,0.009828,-0.006006,0.001477,-0.000128,0.193321,0.000000,-0.000000,-0.012426,0.013944,-0.005822,0.001065,-0.000072,0.033602,-0.000000,0.000000,0.114971,-0.084421,0.024708,-0.003198,0.000148,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000],
# noqa
[4.000000,0.591404,-0.006160,-0.042816,-0.066130,0.187720,-0.106394,0.022798,-0.001696,0.187397,-0.001931,0.003310,-0.003362,0.028349,-0.016599,0.003551,-0.000265,0.404017,0.123323,-0.012757,-0.051193,0.034822,-0.010324,0.001522,-0.000091,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000],
# noqa
[4.000000,0.344652,-0.219351,0.157781,-0.103693,0.138984,-0.067086,0.012914,-0.000884,0.488076,0.106046,0.007999,-0.030793,0.027924,-0.011060,0.002025,-0.000140,0.501396,0.003277,-0.005918,-0.013991,0.021827,-0.010559,0.002149,-0.000159,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000],
# noqa
[4.000000,0.647027,-0.235211,-0.105306,-0.007191,0.084756,-0.033382,0.004731,-0.000227,0.889512,0.105266,0.002150,-0.017544,0.016311,-0.006207,0.001062,-0.000067,0.499734,0.006598,0.001289,-0.026125,0.028361,-0.012261,0.002376,-0.000172,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000],
# noqa
[4.000000,0.728248,0.093861,-0.141645,0.026386,-0.114216,0.085890,-0.021505,0.001786,1.287086,0.102721,0.013152,0.005535,-0.030830,0.020611,-0.005093,0.000430,0.500684,0.007531,-0.002636,-0.030253,0.035578,-0.015451,0.002946,-0.000208,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000],
# noqa
jonasdn
Re: Problem uploading the trajectory to the autonomous_sequence_high_level.py.
Post by jonasdn »
Hello rago7!
Could you make sure you have the latest version of the library (cflib) installed? It looks like it is a version that does not support the "write_failed_cb" argument to write_data.
You can check your current installed version by: $ pip show cflib
rago7
Post by rago7 »
Hi, I just checked the version and is the 0.1.12.1, Do you know which version support the "write_failed_cb"?
jonasdn
Post by jonasdn »
No, not at the top of my head, but you should strive to always have the latest version of the library installed. So try to upgrade it using pip install or yse the latest VM from bitcraze: https://github.com/bitcraze/bitcraze-vm/releases/
And follow instructions from: https://www.bitcraze.io/documentation/t ... ualmachine
