I have several problem when i tried to fly two crazyflies with the motion capture at the same time.After making the markers on the two crazyflies,i tried to ''roslaunch crazyflie_demo multi_hover_vrpn.launch'' in the terminal,but there ws only one drone got off,and the trajectory of the drone was irregular,another drone had no response.How could i solve the promble?
Fly two crazyflies with the motion capture
gpczygpczy
Hi,everyone
I would really appreciate your help!
Re: Fly two crazyflies with the motion capture
For new projects and especially if you want to fly multiple Crazyflies using ROS, it is recommended to use the Crazyswarm instead. If you encounter any issues, you might get better help by opening a discussion question on the Crazyswarm project.
gpczygpczy
Thank you for your replay.If I don't use the Crazyswarm,how could I fly two crazyflies at the same time.
You can write a python script that connects to your mocap system and pushed the position (or full pose) to the Crazyflies.
I'm not sure which mocap system you use, but we hava an example for a Qualisys system in https://github.com/bitcraze/crazyflie-l ... mmander.py
Maybe you can get some inspiration there?
