Hello Kimberley
I am running into a problem when creating the image for gapsdk v3.6 on docker, I get this error:
pathspec ‘tags/release-v’ did not match any file(s) known to git.
The command bin/sh -c cd gap_sdk && git fetch —all —tags && git checkout tags/release-v${GAP_SDK_VERSION} && git submodule update —init —recursive’ returned a non-zero code :1
And the process stops here. Could you let me know what am I doing wrong.
By the way I am now using the olimex compiler.
Regards
Rodrigo
Docker issue
Re: Docker issue
hi!
Which OS are you building the docker image on? This was done on Ubunti 18.04 and 20.04
You are supposed to get pathspec ‘tags/release-v3.6', so probably the GAP_SDK_VERSION is not set properly. Try this again in the same window as you docker:
and try to check it with
You can also put the version variable permanantly in your bashrc file. See the instructions here.
export GAP_SDK_VERSION=3.6
echo $GAP_SDK_VERSIONRe: Docker issue
I created a pull request to solve this problem.
https://github.com/bitcraze/AIdeck_examples/pull/34
Make positive impact.
