No Valid Solution for basestations
Johannes214
Re: No Valid Solution for basestations
Post by Johannes214 »
Thank you both for the help! Everything works now and I was able to obtain base station geometry using crazyflie. I will keep eye on the VM update.
Post by kimberly »
Great! It wasn't obvious to me either that that would have worked but good that kristoffer had seen this before. Start a new thread if you are having any mor e problems
