I've just bought a nice new Rage 1S 3.7v 250mAh battery https://www.modelflight.com.au/rage-rc- ... ttery.html and shaved the connector down so I could revive my old Crazyflie 1.0
I installed the latest Python cfclient 2020.09.1 using pip3 install -e . and updated both the Crazyradio firmware to 0.53 and Crazyflie firmware to cf1-2017.06.bin.
The Crazyflie connects and flies beautifully (woo hoo!), but the flight data isn't coming in. I don't see:
- Battery status
- Volts
- Flight data
When I'm connected, the UI doesn't update past Connecting to radio://0/48/250K ..., so I suspect the self.connectionDoneSignal https://github.com/bitcraze/crazyflie-c ... in.py#L214 is never getting called.
I saw this old post from 2014 viewtopic.php?t=1164, but the codebase seems to have changed too much to use the same fix.
I was also pointed to viewtopic.php?f=6&t=4399&p=20039&hilit= ... old#p20039 by knmcguire, so I tried both Ubuntu 20.10 and the Bitcraze VM 2018.12, but see the same behaviour in both of those OSs as well.
Any ideas?
Cheers, Simon.
Original post on GitHub issues: https://github.com/bitcraze/crazyflie-c ... issues/452
## Debug
Cfclient
Cfclient version: 2020.09.1-14-gcb1d399
System: darwin (macOS Catalina 10.15.7)
Python: 3.8.6
Qt: 5.12.9
PyQt: 5.12.3
Interface status
radio: Crazyradio version 0.53
udp: None
UsbCdc: No information available
prrt: No information available
Input readers
PySDL2 (1 devices connected)
Input devices
PySDL2: (0) Sony PLAYSTATION(R)3 Controller
Crazyflie
Connected: None
Firmware: None
Decks found
Sensors found
Sensors tests
