Hi @kimberly, I recently ran into the same issue. The fixed firmware (cf2_2020.02_uSD_increased_heap.bin) unfortunately did not help in my case.
So to recap the issue :
- The drone is able to start and fly with the optical flow deck pluged in and fully fonctionnal
- The drone is able to log data to the sd card without the optical flow deck
- BUT when I try to plug simultanously the µsd card (with a config.txt file in it) and the optical flow sensor, the drone boot once, then reboot after 3 secound and the M1 led blink 5 time to meaning the initial self test failed.
As tobias, there is no issue as long as the config file isn't in the µsd card.
I tried to flash the latest available software (firmware-cf2-2020.06) and the one on your post.
(By the way with the cf2_2020.02_uSD_increased_heap firmware I can't use any of the Assist flight mode : propellers spins but doesn't take off.)
You can find the console log I recorded bellow.
How can I fix this ?
Thank you by advance !
SYS: Build 32:c9136ceed72c (2020.02 +32) MODIFIED
SYS: I am 0x3934323530374718002F0026 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_CORE: 2 deck(s) found
DECK_CORE: Calling INIT on driver bcFlow for deck 0
DECK_CORE: Calling INIT on driver bcUSD for deck 1
uSD: mount SD-Card [OK].
uSD: Config read [OK].
uSD: Frequency: 1Hz. Buffer size: 10
uSD: enOnStartup: 1. mode: 2
uSD: slots: 6, 24
uMPU9250 I2C connection [OK].
SD: wait for sensors
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [OK].
DECK_CORE: Deck 1 test [OK].
SYS: Free heap: 8664 bytes
STAB: Ready to fly.
uSD: malloc buffer 280 bytes...uSD: [OK].
uSD: Free heap: 8344 bytes
uSD: Filename: log00
OW: Cmd 0x22 timeout.
DECK_INFO: Reading deck nr:0 [FAILED]. No driver will be initialized!
DECK_INFO: Reading deck nr:1 [FAILED]. No driver will be initialized!
DECK_CORE: 0 deck(s) found
SYS: The system resumed after watchdog timeout [WARNING]
SYS: Assert failed at .//vendor/FreeRTOS/tasks.c:4049
