I read the iCE40 Programming and Configuration they mention about SPI Master and Slave configuration which can be use for self reboot after power cycles but I am not sure is it possible for LH Deck.
First attempted to program LH Deck Flash using FTDI USB to UART using the bootloader of lighthouse bootloader-master. I successfully upload the code to SPI Flash. Now I am trying add self booting seciton from SPI Flash and use Nucleo to be bootloader. In addition, the crazyflie is aslo capable of the programming the LH Deck so that it is technically possible.Also how hard to implement crazyflie LH uContoller bootloader in to different uContoller. Looking for advice thank you
