I had earlier version of crazyflie-firmware with lighthouse.c working. However, after I updated all projects, I am having 19 errors in lighthouse.c during "Build"
8 errors related to "Symbol 'false' could not be resolved"
1 error related to "FREERTOS_MIN_STACK_SIZE"
4 errors related to "SYMBOL 'NULL' could not be resolved"
4 errors related to "Symbol 'true' could not be resolved"
2 errors related to "Type 'size_t' could not be resolved"
lighthouse.c compiling errors
Re: lighthouse.c compiling errors
The code base is fine and compiling (https://travis-ci.org/bitcraze/crazyflie-firmware) so this must be related to your environment.
1. Make sure the code base is up to date and clean
If you want to build with lighthouse support, add
to your tools/make/config.mk file
Which version of the compiler are you using? We are using gcc-arm-none-eabi-8-2019-q3 on the build server.
git pull
git status
make clean
make
CFLAGS += -DDISABLE_LIGHTHOUSE_DRIVER=0Which version of the compiler are you using? We are using gcc-arm-none-eabi-8-2019-q3 on the build server.
Thank you very much for the instructions. I work with Bitcraze VM and Eclipse environment.
