[Solved] Crazyflie 2.1 rotating frantically and crashing at specific Yaw-Angle
Hey guys,
So we have a problem where our Crazyflie 2.1 keeps suddenly rotating frantically and subsequently crashing every time it reaches a certain accumulated Yaw-Angle, we were able to pinpoint that this happens at about one and a half full rotations or 3*Pi.
We made the Crazyflie fly the exact same path both with Bezier-Trajectories as well as go_to-commands from the high level commander, happens in both cases.
We're using the Lighthouse positioning System and sending commands to the Crazyflie via CrazyRadio-Dongle from python-scripts.
Our specific use case requires our Crazyflies to travel around in a square or circle around a center-point, all the while facing the center. This only works, as far as we were able to understand, if we continuously increase the yaw-angle. If the yaw-angle is at 2*Pi + Pi/4 (405 Degrees), which would be facing the same direction as Pi/4 (45 Degrees), and we'd set it to Pi/4 the Crazyflie would do a full left-rotation to "get back" to that same angle, so we can't really do that.
We were thinking that maybe some variable in the cflib or firmware is overflowing but it seems weird that this would happen after only one and a half full rotations...
Does anybody have an idea?
Re: Crazyflie 2.1 rotating frantically and crashing at specific Yaw-Angle
Could you let us know which versions of the cflib and crazyflie-firmware you are using?
(btw, due to the holidays we might be slower to respond to your post. )
Hi kimberly,
The firmware was installed by someone else, who is currently on vacation. I've written to him, but don't expect an answer. Is there a way to take one of the 6 Crazyflies I have in possession with me now and check which version was installed?
The version of cflib I am using is 0.1.8.
Please confirm this was the correct way of checking:
$ pip3 list
Package Version Location
cflib 0.1.8 /usr/local/lib/python3.7/site-packages
$ pip3 list
It seems that the cflib is already the newest version. You can check the version of the crazyflie firmware if you connect to one and look at the console tab at the output. You can copy past it here if you are not sure.
About tje bezier curves, it quite a new functionality so it might be that you have hit a corner case that we haven't touched before. I will also ask the @kristoffer to look at this problem.
Not sure what happens. We can compare to the spiral that we fly in the ICRA/IROS demos where we yaw all the time without problems.
Have you tried to yaw the other direction to see if you get the same problem?
Makes sense since the goto function simply generates short trajectories that are played in the same way as the bezier-trajectories.We made the Crazyflie fly the exact same path both with Bezier-Trajectories as well as go_to-commands from the high level commander, happens in both cases.
Here is the information about the firmware I was able to extract from console tab while connected to my Crazyflie 2.1 (Drone 04):
SYS: Build 77:7d344cde570 (2019.09 +77) MODIFIED
SYS: I am 0x20373357594B5008002E0024 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_CORE: 1 deck(s) found
EEPROM: I2C connection [OK].
SYS: Free heap: 6616 bytes
LH: Lighthouse bootloader version: 2
STAB: Ready to fly.
LH: Firmware version 2 verified, booting deck!
LH: Synchronized!
Got calibration from 0080B76D
phase0: 0.006618
phase1: 0.006195
Got calibration from 187CFC03
phase0: 0.008850
phase1: -0.053009
I assume it says "modified" because of the Lighthouse updates.
STAB: Ready to fly.
LH: Synchronized!
phase0: 0.006618
phase1: 0.006195
phase0: 0.008850
phase1: -0.053009
Is it possible for you to provide a python script that reproduces the problem? Preferably as simple as possible
Alright, so we found and fixed the problem.
Then we compared the script which worked to the script in December which did not work and we looked for other differences besides the clockwise/counter-clockwise flight and besides the clockwise/counter-clockwise yawing.
We found three differences and ran tests:
Do you want a video and the accompanying python script?
We took an older version of the autonomous_sequence_high_level.py script and had the drone fly counter-clockwise around the center and had the drone yaw counter-clockwise and it worked! (In December, we were having problems doing the mirror version of this: flying clockwise around the center and simultaneously yawing clockwise, so that the head was always facing the center.)kristoffer wrote: ↑Fri Dec 27, 2019 11:24 am Have you tried to yaw the other direction to see if you get the same problem?
- The Height:
versus
commander.takeoff(1.0, 2.0)The altitude of 30cm versus 1m had no effect, as expected.Code: Select all
commander.takeoff(0.3, 2.0)
- The Order:
In one script, commands were called in one order:while in the other script, these two commands were called in the reverse order:Code: Select all
activate_mellinger_controller(cf) reset_estimator(cf)We ran tests with only this change and the order of these commands being called also seemed to have no effect on success or failure.Code: Select all
reset_estimator(cf) activate_mellinger_controller(cf)
- However,:
versus
cf.param.set_value('stabilizer.controller', '1')definitely revealed a difference in behavior in regards to the YAW.Code: Select all
cf.param.set_value('stabilizer.controller', '2')
When set to '2', the Crazyflie has no problem yawing infinitely (or at least up to 10 rounds) in either direction. But when set to '1', the PID-Controller is activated instead of the Mellinger Controller and that's when we see the Crazyflie behaving oddly after 1.5 yaw rotations.
It seems as you have hit two issues at the same time.
The unwinding part is a feature of the high level commander, it is designed to rotate to yaw=0 at take off and landing. This is maybe a behaviour that we want to change and I created an issue for it https://github.com/bitcraze/crazyflie-f ... issues/532
As you have noted, there also seems to be a problem with the PID controller when you go to yaw > 2 * pi. I created an issue for this as well https://github.com/bitcraze/crazyflie-f ... issues/533
Thanks!
Thanks!
This should now be fixed. You need to update the Crazyflie firmware as well as the python lib to make it work.
I have added an optional yaw parameter in the takeoff() and land() methods. If set it to an angle (in radians), the Crazyflie will yaw to that angle during takeoff/land. If set to None, it will use the current yaw of the Crazyflie. If not set at all it will use the old behaviour, yaw=0
The changes are implemented in:
https://github.com/bitcraze/crazyflie-l ... issues/134
