Flow deck issue
Flow deck issue
Hi Crazyflie team, i'm trying to perform a swarm using 5 Crazyflie with flow deck ad the code in cflib "swarmSequenceCircle". The drones take off, but after a while each of them goes in a random direction, there seems to be problems with the drone imu and the flow deck, how can i calibrate the imu and the flow deck?
Thanks in advance
Thanks in advance
Re: Flow deck issue
Can you be a bit more precise in the description, e.g. when do they take of in random direction? Did you place the CF2 in the direction of the "ASCII" art as drawn in the swarmSequenceCircle file.
If you fly only one with e.g. flowfigure8 how does it fly then? I'm thinking maybe the tracking surface is not feature rich enough or possible shadows casted under the CF2 fools the flow sensor.
Re: Flow deck issue
Hello, and thanks for the answer.
I placed the Crazyflie as illustrated in the script, I did new tests and I noticed that: in the flowfigure8, the drone follows the path quite well, but in some places tends to destabilize, as if it losing power, in Crazyflie's client I also noticed that when it is stopped on a flat surface, the imu is not stable, it keeps moving with small tremolos. is there a way to calibrate the imu? or even the flow deck?
Thank you.
Thank you.
Re: Flow deck issue
If we could see a video it would be easier to know what is happen. From your descriptions it sounds like there sometimes is not enough features on the ground or that shadows is fooling the flow deck.
The "unstable" IMU when landed is because of noise from the flow deck and that is normal.
The performance of the flow deck could probably be improved a lot as there are many corner cases that are not handled now, like what should happen when flow tracking is lost...
Re: Flow deck issue
Any update about this problem?
I have the same problem. Any suggestions?
Re: Flow deck issue
@faria Can you please describe the problem you are getting with the flow deck?
Re: Flow deck issue
Thanks Arnaud.
System:
Crayflie 2.0 and 2.1
V2 Flow Deck
Loco Position
Problem: When I´m using the flow deck I have lot of noise in pitch and roll and yaw (height stable). Without the flow deck, only with loco position I dont have noise.
video
https://drive.google.com/file/d/14IvHa2 ... Jo9gS/view
System:
V2 Flow Deck
Loco Position
video
Re: Flow deck issue
With Flow and Loco i have this noise on the figure "withFlowandLoco.png"
Without Flow and with Loco i have less noise on figure "withoutFlow.png"
Re: Flow deck issue
This looks like noise from the LPS itself. Do you only have the noise on the ground or also after take-off? The flow should mostly be used by the estimator when the Crazyflie is flying.
Re: Flow deck issue
Thanks Arnaud.
In ground I have noise. When i am flying sometimes the drone have 'crazy' movements and after crash. I realized several tests in different places (external noise) but i have the same results.
Tests *5:
Flying with LPS and FlowDeck, with the same drone and the same mission. Takeoff, waiting 5 minutes, and land. On five tests, 2 i have problems (crash) and 3 perfect flight.
Tests *5:
