Hello All,
I want to print the position of each drone of my swarm using swarm lib. I tried using log lib etc, but without success (a lot of problems). How i can do it?
Thanks a lot
						Print Swarm Position - Individual position
Re: Print Swarm Position - Individual position
I think you will have to setup an async log block for each Crazyflie. Using the swarm API you can run a function for each Crazyflie in the swarm (https://github.com/bitcraze/crazyflie-l ... rm.py#L110) so you can write a function that setups a log block containing the position estimate variables.
An example of such a function can be found in the autonomous sequence example: https://github.com/bitcraze/crazyflie-l ... #L109-L124. One trick when dealing with multiple Crazyflies is to use the python lambda function to call a callback with an extra argument: you want your log callback to be called with the identity of the Crazyflie and this could be achieved with lambda:
    # In this context, the current URI of the crazyflie is in the 'uri' variable
    log_conf.data_received_cb.add_callback( lambda timestamp, data, logconf: position_callback(uri, timestamp, data, logconf) )
Hello Arnaud,
Thank you for the quick reply!
We were using the code from "hl-commander-swarm.py" to which we now added the "automousSequence.py"'s functions "start_position_printing" and "position_callback" as suggested in your post.
They seem to work fine when the swarm is constituted by one drone alone, but not when the swarm is bigger. I assume that is why we would have to add the "uri" parameter via the lambda function? We did try that but we get the error "NameError: name 'uri' is not defined". I suppose we're missing something?
We have used the uris to construct the Swarm object, and then call its method "parallel_safe" with the" start_position_printing" function as an argument.
We also tried with the "sequential" method as you referred but with the same result.
Any thought on what we're doing wrong?
When using parallel_safe, the same way it is used in other part of the code, you can get the URI from "scf.cf.link_uri". This should allow you to setup the log block the same way it is done in autonomousSequence but  with the Crazyflie URI parameter
Hello Arnaud,
It did work out, we are finally able to get each drone's position!
Thank you loads for your help, it is greatly appreciated.
Inês
Inês
