When I when the launchBootloader.py script I get this error: Error!, cannot find the CrazyRadio USB dongle!
The dongle does not show up in lsusb and I do not see anything about it in dmesg. It also does know show up in Zadig on Windows. The LEDs light up for a few seconds when it is plugged into a USB port but nothing more happens
Swiftflame
Re: Error!, cannot find the CrazyRadio USB dongle!
What driver has been installed on Windows? It should work with both libusb32 and libusbK. When you have restarted to bootloader mode you will need to install the usb Driver for it as well.
One question though: why do you want to reflash the Crazyradio? You should not have to reflash it if you want to use it with Crazyflie from Windows.
