I'm struggling to get the VM working as described in the tutorials. I have managed to install the Windows drivers and run the Crazyflie client successfully (on Windows). I have also had success with the example Python scripts. All that to say I believe I have all things set correctly on Windows.
However, when I open the VM on Virtualbox, things no longer work as suggested by the tutorials. With the Crazyradio PA connected, I click the USB icon on the bottom right of the VM screen and try to select the Crazyradio PA to no avail.
I get the following message:
When I run
lsusb
I haven't found another case reflecting the same conditions of this issue, but I'm also not experienced with virtual machines or even Linux for that matter, so I'm sorry if you already solved this one. I appreciate your input.
Thanks!
